Starboard trivia
2 pieces of Starboard trivia I picked up over time are, firstly, that it has a fairly low melting point--200 degrees f., so you won't want to put the barbecue under that hard dodger. Secondly, the instructions that come with it tell you to avoid marking it with pencil because the marks are hard to get off, so abrasions will mark it up over time.A number of newer boats including Catalina have some kind of starboard-like material for hatch boards, so it should be possible to use it for that application. the 3/4 inch thickness you might typically use for hatch boards will be heavier than the equivalent in wood. UV resistance might not be great, so it's a better material for below-decks than above.
