What brand opening ports 2008 H36?
62
Hunter MH 40 Noank, CT
Both of the opening ports in the head leak when it rains. Water pools outside at the bottom, where the black gasket meets the glass, and then drips onto the sink and behind the toilet. I can't seem to figure out what brand of ports these are by searching on the web. Does anyone know?
The latches that keep the glass closed against the gasket are small and are held in with a phillips screw. Seems pretty flimsy. My H260 had some fairly heavy dogs to keep the ports shut.
Anyone have any experience with these ports?
Thanks in advance,
Zig
DougMc
Hunter 36 Erieau Ontario
On my H36 I had a bit of a problem. I wiped a little vaseline on the seal and solved the problem.
Dec 5, 2009
80
Hunter 36 Hernando Beach, FL
tightening post dogs
There are small adjusting screws in the black port dogs that tighten the port light against the gasket. You might want to try adjusting those as well as lubricating the gasket
Nodak7
Sep 28, 2008
1,256
Hunter 41DS Punta Gorda, FL
Thanks in advance,
Zig
Zig, if it looks like the picture it is a Bomar and indeed the dogs keeping the window closed has a small adjustment screw in it.
As you can see from the picture I had the same problem and thus the piece of paper under the dog. I have since adjusted the screw and the leaking is no longer a problem!
Good Luck!
