Why bother?
The purpose of bottom paint (or more correctly, "antifouling" paint) is to deter hard marine growth like barnacles from growing on the hull and creating drag. With the possible exception of zebra mussels (which are found in a limited area) these creatures do not live in fresh water. They also need time to grow, so unless you are in an area known to have zebra mussels AND you leave the boat in the water for more than a month at a time, you don't NEED bottom paint.Bottom paint doesn't stop blistering, and most bottom paints won't stop algae and slime, either. Manufacturers recently started added algaecides and slimeblockers to their paints, and of course the price went up. Again, unless you plan to leave your boat in the water long enough for growth to start, you probably don't need bottom paint. Talk to a few boaters around the local docks but don't just ask what kind/brand of antifouling they use...ask them WHY. You might be surprised.However, if you really need bottom paint, I'd suggest VC17. It's smooth, quick and easy to apply, durable enough to stand up to the rigors of trailering (and the occasional scrubbing to remove algae) and stays effective even when out of the water for extended periods. I've been using it for the last seven years with much success. Check the archives for some of my past posts about VC17. Good luck.PeterH23 "Raven"
