Good points Jack
I am in the final stages of blister repair on my 1988 H23 and based on my observations, I agree that the potential for blisters probably has more to do with the quality of the layup than anything else. The boat has been sitting in warm fresh water (the worst environment for blisters) for the last five years.Most of the hull was in fair shape, but there were some areas that were pretty bad. The blistering was not the same on both sides of the hull, so it couldn't be attributed to location or depth below the waterline.Almost all the blisters were under the gelcoat, between the first layer (chopped mat) and second (first layer of structural cloth) layer of laminate. In many cases, these two layers were visibly separated, even though there was no blister and the laminate was dry. Areas that appeared to be small blisters (about the size of a quarter on the surface) had to be ground back until I found properly bonded laminate. Some of these areas ended up being several inches square, though none went into the structural laminate.After grinding out and cleaning the blisters with acetone, I applied 1 coat of Interprotect 1000, filled the ground areas with Interlux Watertite, sanded everything fair and then applied a second coat of Interprotect 1000. I'm now about to apply 2 coats of VC Tar, followed by 2 to 3 coats of VC-17 antifouling. This should provide decent freshwater protection while still being tough enough to stand up to the rigors of trailering.PeterH23 "Raven"
