What at PITA! Prepping to repaint the deck
73
Hunter 25_73-83 St. Clair Shores
I am startig to get the deck ready to repaint. The best I can tell is that on top of the original gelcoat is a older off-white paint - painted everywhere - then a gray paint where for the non-skid. So, the non-skid is applied OVER this off-white paint. The off-white paint is peeling lightly in areas. As the picture shows the non-skid is really peeling on the port side walkway - but for the most part no where else. My question and concern is that I used a scraper/putty knife to scrape this damaged area and it worked well - but as I kept scraping in different directions I was able to keep removing the paint(both the non-skid and the off-white beneath it). It came off easily in some areas, harder in others. I am now worried that all the off-white paint is junk and the entire deck needs to be stripped down to the gelcoat. I spent 2 hours with 60 grit on a powersander on the foredeck and thought it would be good enough since I saw no signs of peeling. BTW the 60 grit did not do much to the grey paint and just barley thinned it out....I would have thought it would sand it off quickly and I would get down to the gelcoat. Any thougths? Would a powerwasher be worth a try since the paint is peeling anyways? I would REALLY rather not use a chemical stripper. I just don't want to sand the prime and paint onto a surface that may peel. Many, many thanks for any advice on this frustrating task that has only begun!
G
Gerry, GMJ Marine
Painting prep
Deeman, Sounds like the original prep may not have been done thoroughly and that's a pity for you. Don't make the same mistake. The integrity of the old paint is shot and it should be removed to assure the quality of your paint job. I wouldn't use a power washer since it could easily loosen the seal of any bedding compound used for stanchion bases or your aluminum toe-rail. I use a putty knife type scraper with a stiff blade to hand strip bottoms when the bottom paint starts to let go. A scrape against the edge of a peeling area removes around 3-4 sq. inches at a time. A couple of years ago I did a 38' sailboat bottom this way in 15 hours, down to the gelcoat. It would've taken a lot longer trying to sand it all off to the gelcoat. It sounds like you were having similar success with this method, so stick with it until it doesn't work any more . Then you might try Peel-Away for the rest. Good luck with the project.
steve rainey
Painting Deck
I just went thru this, your working to hard. Go to Home Depot and get the stripper thats for fiberglass. Reading the directions, a couple of types mention don't use on fiberglass. Us the one that doesn't mention it. It works great, no problem with damaging the gel coat. Suggest you use the west marine products for deck paint, a 2 part Interluk apoxy called perfection. Its a little expensive but I'm very pleased with it. Don't use the 1 part apoxy unless you plan on selling the boat within a year. It will peal and won't hold up.
jayden
Aug 10, 2005
4
- - San Francisco
heat gun
use an electric heatgun to soften the paint.then use your scrapper to lift it while it is hot and bubbling.its old fashioned,effective, easy and quick.
Jun 25, 2005
73
heat gun and strippers!
Thanks for the feedback everyone. I may try to manually scrape some more, then try the heat gun and if that does not work the stripper. Thanks again!
