What are tthhese things?
Apr 8, 2017
30
Hunter Cherubini 36' chherubini Poughkeepsie
I have a Hunter Cherubini 36'
I have these things by the engine key and lights
On the starboard side
I'm not sure what they are
I wonder if the large black covered thing is a Manuel bilge pump?
I also have 3 lines going into my mast
1 - 3/8 liine to raise my main sail
And two others.
Possibly one - 1/2 to lower the Jiib after its unfurled?
I'm not sure what the other 1/2 line goes to
Dec 29, 2015
80
Beneteau 473 Mukilteo WA
The second picture is a manual bilge pump. There should be a small metal rod that is used to pump. The last picture is a 12 v outlet. Used for a deck light or other appliance.
Likes: sailscallny
Nov 8, 2007
1,617
Lines in your mast:
1 - as you say your main halyard to hoist your main sail.
2 - as you guess your jib/genny halyard to hoist (or lower) your fore sail.
3 - either a spinnaker halyard to hoist a spinnaker (in which case, the other end of the line with a shackle for attaching the sail should be somewhere in the forward part of your boat), or it is a topping lift used to raise or lower the aft end of your boom.
Likes: sailscallny
