What Are These?
Jun 11, 2023
89
Hunter 27 Deer Island
Can anyone tell me the purpose/use of these two black colored, plastic rings (see attached pictures)?
They were on my Hunter 27 (1984) when I purchased it (and the previous owner is no longer able to provide any insight).
Mar 6, 2008
1,527
If you look below the black ring, inside the cabin, you will find a hole. After the mast is put up some of its cables, such as the antenna coax is fed through this ring. There should be a rubber gasket as well that prevents water from dripping down. You normally remove the black ring, feed the wires through, then screw it down. In the image you have posted, I do not see the rubber gasket. It appears that the opening is plugged up.
Looking carefully at the deck layout, the gland for coax cable and such, doesn't make sense to me. The rings are located immediately behind the dodger snaps, inside the dodger, and nowhere near the mast.
Maybe some sort of padeye for anchoring something temporarily to the coachtop? Is this a Hunter 27-2, or 27-3, I don't see examples online of Hunters with that molded dodger combing.
-Will
4,790
Catalina 30 MKIII Chicago
It Looks like a coffee and ice cream swirl in the middle. Drink up!
What is the material in the center as well as along the inner diameter? It looks like there's some rubber remnants of a seal or something similar
-Will
The expected place for a gland is near the mast, however, glands show up in other places, the 3 glands on my boat are on the transom. Glands near the dodger can be for solar panels, instruments, or entertainment systems among other things.
The symmetry leads me to believe they aren't for instruments or solar panels. Maybe stereo entertainment systems, but they really don't look like patched holes. The deck beneath looks to perfect and why not remove the rings if you're closing them up? There is a hollow look to the rings that makes me think something is suppose to sit in the ring, like a leg or a post.
cable gland.
An example of a removable pad eye.
A quick-release deck ring table mount.
-Will
Jun 11, 2023
89
I took a second look and there's no hole (not inside nor outside).
It's clearly not for cable routing/access.
The mystery remains.
Jun 11, 2023
89
View attachment 240485cable gland.
-Will
I appreciate your reply; thank you.
I've no real plan to remove them; I simply wanted to know what their purpose is.
Neither have a thru hole.
They do look much like the quick release deck ring table mount you reference though.
