What are these? Symmetrical underside patterns near keel
SeanP
Jun 6, 2017
87
Hunter 31 Portland
I have just had my newly-acquired H31 1986 hauled for bottom paint. I noted these strange, but regular looking, patterns on each end of the keel on the underside. Does anyone know what these are or what they are caused by?
The yard thinks they are a crack, but it seems way to regular to me to be a crack. The pattern is on either side, both ends of the keel for 4 in total.
Thanks!
10,256
That is the top of the keel casting.. The keels on the 31 and the 34 have ears that give the top of the keel a lot more support . The ears are recessed into the hull .. that said, the crack between the ears and the hull opening means that the keel may be moving a very little bit. It would be good to tighten the keel bolts once the boat is in the yard and resting on the keel.. After tightening, the little gap can be filled and faired..
Likes: Don Crowther
SeanP
Jun 6, 2017
87
Hunter 31 Portland
Just to close the loop on this...the yard tightened the keel bolts, filled in the cracks and all is good. She is back in the water.
Likes: mnmpizza
