What are the top four sailing vessels I should consider?
537
Hunter 386LE San Fancisco
I recommend a hot tub, dodger, full bimini, dinghy davits, dinghy, and home theater with surround sound inside and out.
Tim R.
May 27, 2004
3,626
Capt Karl said:
I am looking for a Sailboat that has:
1. Great comfortable onboard living for four and an ‘occasional’ guest or three.
2. is reasonably swift,
3. sails well and
4. Is seaworthy for blue water.
5. A nice navigation station below deck, with
a. adequate storage for charts
b. navigational accoutrements
c. Weather and wind instrumentation
d. GPS station with link to bridge
e. Marine radio
6. Something with good storage of
a. Supplies of all sorts!
b. Equipment and gear
c. food (Refrigerator AND Ice Box)
d. Chinaware, utensils and accoutrements
e. Hanging lockers for both cabins
f. Good amount of drawers for both cabins.
g. Plenty of fresh water
h. Generous holding tank
i. Generous fuel capacity.
7. Certainly 38' plus in length and say 12'+ beam.
8. Two (or more) cabins plus a center cabin.
9. Must have ceiling to make a 6’4” person not duck.
10. Something 'home-eee', inviting and comforting below deck.
11. Something with nice walk-ability and lay-ability topside to use most/all of the topside deck space as we love being outside in the sun and roaming around a deck.
12. A diesel engine that is efficient and dependable.
13. Two heads.
14. Two showers would be nice but not necessary.
15. Mast/s and rigging that work well and with reasonable ease.
16. Autopilot
17. Love teak below deck, but must just be nice and uplifting inside.
18. Need plenty of natural light coming in below deck.
19. Need plenty of visibility to the outside from below deck. Must be able to see outside, hopefully around much of the vessel, reasonably well from below deck. Large portlites in main center cabin area.
20. Would ‘like’ to see stainless steel opening portlites in cabins.
21. Hatches in both cabins to deck.
22. Well equipped, comfortable, and functional and uplifting galley area.
23. Love to swim, shave and groom at the stern so it would be nice to be able to facilitate such with a swimming platform (might be willing to give this up for the right vessel).
24. Hopefully a generator in addition to:
25. Solar and/or wind generator.
26. A dingy hoist would be preferable.
27. Radar integration with GPS, Chart plotter and bottom sounder/fish finder.
28. Pulpit with two anchors, one to be a Bruce. Windlass would be a plus.
29. Good deck lighting when needed/desired.
30. Hailer
31. All the proper safety equipment as required
This is not a list for the purchase of a vessel. I am providing this enumeration for in the effort to convey what I am looking for in a vessel so that you knowledgeable sailors can give me some advice as to what are the top four choices of vessels from which to choose.
All for a very reasonable price, so that I and my family can do this. A used vessel, well maintained, with logs and maintenance well recorded, is just fine!
I have been trained to sail, as a young man and have a fair knack at it, but I have been a power boater for 30 years. I have a lot of experience and knowledge (and love for) of the sea, but not so much with sail.
Please be so kind as to provide this skipper, relatively new to ‘sailing’ with your recommendations.
Easy. caliber 40lrc is the closet you will find to your list. But you forgot time machine, shape shifter and perpetual motion machine.
higgs
Aug 24, 2005
3,738
Nassau 34 Olcott, NY
You seem to have your needs clearly spelled out. You don't really need us. Just start looking at boats and go through your check list. The right one will be obvious to you when you find her.
Jun 11, 2004
1,944
Oday 31 Redondo Beach
This has got to be an existing poster posing as new and just yanking our chain doesn't it?
Ross
Jun 15, 2004
14,693
I will be glad to help him look for a 10 per cent finders fee.
Joe
Jun 1, 2004
8,351
Geez.... I have a headache looking at that list. Why don't you find four and ask us what we think.... that's way too much work unless a commission is involved.
Jun 6, 2006
6,990
The short list
A lot of the things on your list are not "boat" specific. All boats should have them or could have them as an add on. Sooooo, what you are really looking for is:
3.
c. Refrigerator AND Ice Box
12. A diesel engine
13. Two heads.
28. Pulpit with two anchors, Windlass would be a plus.
But we still do not know what you intend to / how you intend to use the boat. some of these are mutually exclusive. For instance sails swiftly and roomy in side. Also what is the priority of this stuff? Is fast blue water passage more important than comfort at anchor? Most would say that since you don't spend much time sailing between ports and do spend the majority of your time at anchor/slip you would want to prioritize the "at anchor" features and suffer with "sufficient blue water capabilities" and then invest in a weather fax and a book on how to read them to avoid the majority of "blue water issues" which typically look like large waves
May 4, 2005
4,062
[FONT=Verdana, Arial, Helvetica, sans-serif][FONT=Verdana, Arial, Helvetica, sans-serif]^ Hylas 46 [/FONT][/FONT]
money is no object right?
[FONT=Verdana, Arial, Helvetica, sans-serif][FONT=Verdana, Arial, Helvetica, sans-serif]Hylas 54'
http://www.sailboatlistings.com/view/23308
[/FONT]
[/FONT]
Jul 27, 2011
5,203
Bavaria 38E Alamitos Bay
Go to the advanced search option @ yachtword.com. Plug in minimum size (e.g. 38'), maximum age (newer than yr 2000), and maximum dollars or range (e.g., 90,000 to $130,000), then search the various geographic regions. Check the specifics of the candidate yachts for your criteria. Bigger, better, newer boats cost the most. Do this at least a couple of times a month or even weekly for a while and you'll eventually see what sells and what doesn't (= tacit recommendation).
http://www.yachtworld.com/core/listing/advancedSearch.jsp
961
Macgregor & Island Packet VENTURE 25 & IP-38 NORTH EAST, MD
Gathering the info from a previous post (one ROSS will remember), I believe the obvious choice for this skipper should be a Soleil 46 or perhaps a good used C&C 40
