Sloops are for racing, ketch is for cruising
If you wanna race, get a sloop, if you want to cruise get a Ketch. Actually, on a long haul race, I'm not so sure that a sloop will always beat a ketch. Given the different sail plans available to a ketch and the limited sail plans of a sloop, the ketch may just have the advantage.I might be wrong, I'm not a designer, but isnt windward ability largely dependant on keel shape also?Most sloop people pass over all of the options you have available to a ketch during all differing weather and sea conditions as if they are not really important. Its not just the better balancing, its also that when the weather kicks up, you just drop the main and sail jib and jigger(jib and mizzen). No reefing required. You can sail balanced, fairly vertical and still maintaing hull speed. This is a major plus. This makes life easier for an older couple or a shorthanded crew. Rich states " A ketch is probably most efficient at broad reaching, CE in the mainsail, suffers when beating due to the mizzen being in the wind shadow of the main." Mizzen being in the wind shadow? Ever think of dropping the mizzen while beating.? Its obvious when that happens. Also I'm not sure where he gets the mostly downwind sailing thing. I read somewhere that John Cherubini favored the ketch rig as many other designers have.As for Brian, I would strongly recommend a ketch if you plan on ocean sailing, even if only overnight trips.I have sailed several overnight passages on sloops and 1 long trip on my ketch. There is no comparison. We sailed for several days in 30 to 35 K winds and with just the jib and mizzen , we maintained hull speed and hardly heeled over. When the wind kicked up, it was much easier for one man to drop and secure the main than to reef it.Extra work? A mizzen is fairly small it requires one halyard and one sheet and is usually centered most of the time and requires little to no attentionTony B
