What A/C-Heat unit for Hunter 356
Oct 8, 2013
46
Hunter 356 Connecticut
We are trying to decide what A/C-heat-dehumidifier combo unit is best to have installed in our Hunter 356. It is a 2002. MARINE AIR AIR CONDITIONER SYSTEM 16000 BTU COMPLETE was recommended to us by a couple of dealers...Looking for thoughts and help from others that might have also installed units on their boats..
Thank you for any suggestions.
Best,
Lauri
Mar 20, 2004
1,753
We've been really happy with the mermaid 16k btu reverse cycle unit we installed on our 2002. very reliable, excellent performance, quality construction. Fit nicely under the dining settee next to the refer unit
Mar 3, 2003
710
Hunter 356 Grand Rivers
We are trying to decide what A/C-heat-dehumidifier combo unit is best to have installed in our Hunter 356. It is a 2002. MARINE AIR AIR CONDITIONER SYSTEM 16000 BTU COMPLETE was recommended to us by a couple of dealers...Looking for thoughts and help from others that might have also installed units on their boats.. Thank you for any suggestions. Best, Lauri
Our 2003 has the MarineAire 16,000 BTU unit. Thru hull is grouped with the others at bottom of companionway steps. Pump is below sink cabinet and pump thru hull on starboard side above water line. Install a drain line from the condensate pan into the shower sump pump located with thru hulls. Standard factory installation had unit draining into the bilge, but this will give you some concern later. Easy to make this change after the fact as most in our area have done so. If I were you, I'd do it in the beginning.
Unit provides good heat in water temps as low as 40'degrees. Have no experience at lower water temps, but plenty of heat at 40.
Mar 3, 2003
710
The MarineAire 16,000 btuh unit is what the factory installed. Add a condensate drain line from the pan to the shower sump pump. We did that and this keeps the condensate out of the bilge.
Apr 21, 2014
185
Hunter 356 Middle River, MD
Always though the air conditioner was plumbed into the shower sump, but while cleaning the filter noticed that both drain holes were empty and drained to the bilge.
Do you have both drains plumbed to a 'Y' that then drains into the sump? Any pictures?
Thanks for any info.
Jeff
Dec 25, 2000
6,071
Hi Lauri, our 1991 P42 came equipped with two reverse cycle MarineAir sea water heat pumps; 16K BTU for the saloon and forward cabin and a 9K BTU for the aft cabin. Both units still work and we use them from time to time mostly for heat while connected to shore power during the cooler months. Our PNW climate does not require cooling, but that side still works, too. If you plan on spending any time away from shore power while cruising and want to use the unit, you will need a generator to operate it. If we operate both units at once (we never do) they will draw about 22amps. One unit will draw about 12amps, which includes the sea water pump that supplies sea water to both units. If either unit requires replacement, we will replace with MarineAir.
Dec 29, 2012
148
Hunter 37 Jacksonville
I installed a Dometic 16k unit a few years ago. It's been fine and has worked well. I picked it up for about half the normal price as it had shipping damage. We are in N Florida so it gets a serious workout much of the summer.
Hunter 37.5 Jacksonville FL
I recommend Mermaid Air. The only manufacturer I know of with a five year warranty. My first one lasted 14 years. As a liveaboard in FL it got it' share of use. Customer er support is excellent
Feb 6, 2013
437
Hunter 31 Deale, MD
Installed a Webasto FCF 16K BTU unit on our Hunter 31 two years ago. Very pleased with it. It will cool the cabin from 85*F to 70*F in about 45 minutes. It's a reverse-cycle so it provides heat in water down to 40*F.
