K
Kevin
I own a 2003 260 and it came with the hard plastic whale plumbing system. The system does not use clamps or plumbing glues for any connectors. The first time I filled the tank I found several gallons of water under both sinks. The elbow joints blew out. Since then I can't get water to run, with the exception of an occasional squirt, from the water tank. I have decided to put in a water pump to help improve the system. However, the system is sized at 15mm. All of the plumbing I find on the market is standard not metric. Has anyone found a sollution with out completely re-plumbing the boat. Or am I over looking something with the current system. If all you ever get is a few squirts here and there then this system sucks and Hunter need to address the problem.
