1. until I spent a few hours on the boat during a rainstorm. It was coming in at the lower edge of the beckson portlet windows and running down the wall in the head.
2. I also had some leakage at the chain plate.
3. These S2's leak like a sieve.
4. I'm in the process of sealing all my deck fittings
5. I'm replacing the cheap plastic beckson windows with proper aluminium ports.
1. Good idea. Most folks try using a hose, but it's never the same as BEING THERE.
2. All skippers should KNOW that chainplates are a part of periodic maintenance. Sadly, most don't.
3. All boats will if not maintained properly.
4. Good idea, use butyl tape. Know what that is?
5. Not really necessary. Beckson makes a very good product. You might want to read up on them before you trash them. Most leaks are due to the need for new seals, which are a hell of a lot less expensive than replacement ports of any manufacturer.
www.beckson.com I have eight on my boat, have replaced two or three but easily refurbished the rest. I like them a LOT. Compared to Lewmars, they're like a Cadillac to a Yugo. Yeah, Lewmars may look better, but they leak like seives. Sound familiar? Becksons can be fixed easily, Lewmars, not so much, although they can be, too. Beckson has been making the SAME size ports for over 30 years. Lewmar keeps changing their sizes.
