wet/dry storage
321
catalina 25, 30 montauk / manhattan
after 2 past seasons wet storage thought about dry this winter; maybe good to let sit out for awhile. however wanted to do some repair (nothing hull) and certainly easier at a slip with electric. no bubbler system however at the very end of a very protected marina. as previous seasons will do short haul bottom paint before spring launch.
any issues with continued wet storage?
Dec 19, 2006
5,836
Hunter 36 Punta Gorda
Dry
I was told it is good to dry storage once in a while and go over everything
under water and let it dry out is good for the boat.
Lube the thru hulls and check and check cutlass bearing and shaft and zincs
all while sanding and clean hull and let it dry and breath over the winter and than new bottom right before splashing.
nick
