I'm goin in...
When we bought Leilani our surveyor found wet core from the aft end of the galley port-light down 15 inches. Saved us $$ but it's time to make good.
I've removed the cabinetry, will remove the plexiglass and eventually rebed with Dow 795 but need to address the core. I know the hull above the waterline is cored with 3/4" balsa but do not know how close to the portlight recess it is. It must be close otherwise the water could not have gotten into it. I will know more once the plexiglass is out, and am prepared to cut away the inner liner then hole saw through the inner hull in the area of wetness to dry out the area.
If anyone has done this ( I looked and looked in these forums) or know useful intel pls share:
I hope to do limited surgery for the purpose of gouging out destroyed core, dry over a period of time then repair. The method of repair is what i haven't settled on yet.
I see posts using numerous 1/4" drill holes to inject epoxy which seems easiest but it seems to me that would fill the void but the bonding between inner and outer hulls would be poor if not cleaned out better..
