Leaks
Here are a few of the areas where I found leaking that resulted in mystery bilge water when I bought my 88. Cockpit drains - rebed, steering quadrant box - clean drain and install new grommets/reseal around wire runs, mast wire run - drilled .060 hole at base of mast, stern locker - added gasketing, stem fitting at bow - rebed, footpump on icebox drain - replaced. My favorite leak didn't get to the bilge but deserves mention, it was an opening portlight that resisted new gaskets, lenses, o-rings and rebedding. Turns out it was one of the expansion joints on the frame, I used silicone to seal it until a more knowledgeable Catalina30 owner suggested Captain Tolley's Creeping Crack Cure. Toilet paper or baby powder is handy when you are trying to track down the source of leaks.
