Westerbeke W46 hard to start
Michael
I have an Oday 40 with a westerbeke w46. The motor starts like a champ hot or cold when on a slip or mooring. After sailing, however, when the boat has heeled over ( 10-20 degrees ) the motor is very hard to start. The fuel tank is full. I have tried clamping off the return hose after shutting the motor off to test if I'm getting air in through the return line but the problem still occurs. To get the motor going I usually jumper the lift pump to 12V and run it for a couple of minutes. I then have to crank the motor several times for about 10-20 seconds before the motor starts. Any help would be appreciated. --------------------------------------------------------------------------------
john
hard to start
do you hold glow plug down for 20 sec? check to see if they are getting correct voltage.
Michael
glow plugs okay
Yes, I hold the glow plugs for 20 seconds. They appear to be functioning properly.
W
Warren
hard start
Make sure your fuel filters are clean & tight. Sounds like your getting "air" in the system somewhere.
