Westerbeke two10 Questions
dennis young
(Q.1) Lowest revs on my two10 in neutral is 1,200. Seems high. Is this standard or should I adjust the cable? At what revs should the two10 stall when in gear? (Q.2) Forward engagement is immediate but reverse engement takes 2 seconds, is this standard or can it be adjusted? Two seconds is an awful long time if you have too much way in the marina.
