A
Aloha Marc
I have an Aloha 28' with Westerbeke 13. The transmission is a HBW MODEL 50
2.7 TO 1 - W1 3A.
Last year I had to replace the damper plate because of
worn gears in the damper plate. This year again I lost power due to worn
gears in the plate.
After examining the plate I notice the transmission
shaft only engage about half the gears. Is this normal there is no
adjustment and could I use longer spacers moving the plate closer to the
transmission and ensuring the shaft if fully inserted in the plate?
Also if
I do this will this adversely affect the engine or transmission?
2.7 TO 1 - W1 3A.
gears in the plate.
Also if
