Hi Guys:
Need some more wise advice again.
I have Westerbeke B30 (3 cylinder) engine 1700hrs on B361. This problem was since I got the boat 4 years ago but don’t know if it is a problem or just instrinsic B30. Someone mentioned they all shakes.
Engine Idling tuned: 1000-1100 as in manual (everyone says is too high) but the
problem is...
1. If set lower than 900 the whole engine shakes and vibrates worse than Elvis.
2. If into gear ONLY (no acceleration added) engine revs immediately drops from 1000 idling into 600-700 and engine do the Elvis severely. So I cannot slowly come into my tight berth on just in-gear below 900 or less without severe vibration!!! Dangerous speed at 1000.
3. Same with reverse.
4. There seems to be NO secondary fuel filter at the engine.
5. Is this normal for Westerbeke B30? (I have a Racor Primary Filter installed).
Anyone with B30 experience please help. Thanks.
Also 3 pencil zincs eroded off and lie tightly stuck in heat exchanger and there is no room to put in new ones thro the normal screw-on hole. Can anyone assure me that those stuck zinc will protect the exchanger until they wear off as I cannot install new pencil zinc in the normal hole without removing the whole thing to extract!!
Thanks Guys.
Guan
problem is...
Thanks Guys.
Guan
