Westerbeke 27A Keeps Shutting Off
Aug 24, 2020
1
Sabre 36 Essex
Just purchased a 1988 Sabre 38 with the original Westerbeke 27A, 1,380 hours. On the original delivery home, I motored dialed for 5 hours, engine ran fine and then abruptly shut off as we were maneuvering for mooring. Topped off the fuel and changed the fuel filters (2); engine starts up ok and runs for 30+ minutes and shuts off. Any thoughts, similar experiences?
Thanks
Jan 4, 2006
7,438
Search the archives here for 1,001 examples of various diesels shutting down, their causes, and the cures.
Jan 4, 2013
289
Catalina 270 Rochester, NY
What I would do is get a diesel fuel can and a brand new piece of fuel hose. Try running the engine off the can, bypassing the whole tank, filter, etc. If the engine runs fine, move the temporary fuel tank to the filter and see if the engine runs ok. keep moving upstream until the problem is found.
Jul 5, 2011
754
Oday 28 Madison, CT
Connections at fuel pump tight and free of corrosion; loose ground wire in my case. First intermittent pumping and then gonzo.
