Hello Members,
Thanks for responses to my other posts! I enjoy your comments and hope to learn from them.
Here's the background info: We have owned two other Odays.....a 30 and a 34 with a Yanmar 2GM20 and a Universal M25 respectively. I believe they both handled very well in reverse and moved through the water at 5 to 5.5 knots without stressing the engines. Our 272LE is powered by a Westerbeke 10 Two and seems to be a bit underpowered although it is a much lighter boat. I confess I do not remember the size and pitch of the two-blade prop that is on the 1 inch shaft. If I can not find that info in my paperwork I will dive to read it off the prop. ( I saw the info stamped on the prop when I was cleaning and painting the bottom, but I did not write it down. Bad choice.)
I have noticed that I can only power up to about 4 knots at about 2600RPM and I have found that the engine and prop will not easily overcome sternway when I need to move forward and turn to starboard after backing out of our slip. I recently did an unintentional 360 with the help of sternway and wind on the bow!
Questions: (1) What props do you use successfully? (2) Do you find your 272 underpowered? (3) Do you think the backing and then having difficulty in moving forward is a function of too much speed in backing to begin with? (In my own defense I only move about two boat lengths astern, and I am backing toward a shallow area about four boat lengths from the end of our slip.) The boat does handle well in reverse.
Respectfully, Phil
Respectfully, Phil
