West MI stainless weld shop
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
Does anyone have recommendations for a weld shop that does stainless fabricarion in Northwestern Michigan?
I need to add reinforcement to the port pushpit rail on my Beneteau 323 so that it can safely support an 8hp 4 cycle outboard. The OEM outboard bracket is poorly engineered and needs to be strengthened.
J Page
Feb 5, 2004
61
Hunter 30 Muskegon MI
West Mi Comm college
Doug,
Up where you are I'd try the Comm. College in Ludigton. I think they have a training program in welding. Should be able to do it for you. They are a school so they can't charge you but make sure to mention to the instructor that you would be glad to offer a "donation" to his program.
Might have to wait a couple weeks to put the plan in place, till school starts.
Otherwise, I may have some contacts down here in the Muskegon Area.
Lugeman
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
You could also just buy some bolt on stuff and use a straight tube.
Ross
Jun 15, 2004
14,693
How much weight are we concerned with in this problem? Can a man sit on the pushpit and not damage it? Shouldn't a good oak plank fastened in place with "U"-bolts be adequate to support a small engine. What does it hang on when in use?
Beneteau 323 Annapolis MD
The actual problem 323s have is the rear-leaning rail does not have a strong thru-deck attachment. Add a motor on the top rail, and there is alot of leverage on the thru-deck rail bolt.
I have the B323 also, and it is a wimpy stern rail, split in the middle for a walk-thru transom. It is not one-inch, but maybe 7/8. It's not a question of the rail itself being strong, and maybe not the motor mount itself. My Honda 5 will make the rail deflect outboard even more, especially when the stern lifeline is undone, so I'm sure an 8 hp will really put a load on it. I'm not sure what he expects to weld, but I suggest a sturdy stainless steel strap from (preferrably) the top rail, but the mid rail might do. Run it down to inside of the coaming (on the seat back) and throu-bolt it with a backing plate in the 1/4 berth.
Ross
Jun 15, 2004
14,693
maybe this isn't a good place to mount an engine. One of the most difficult things to build is a short straight railing because bracing it is all but impossible. If you can spread the feet and make a three or four point attachment it will be much better.
BobM
Jun 10, 2004
3,269
Wow...
Looked at 323's on YW...apologies in advance but that rail is hopefully not an example of Beneteau quality or engineering. I had a better stern pulpit on my 25 footer!
I think the best idea might be to let someone qualified start over. I don't think I'd lean on that never mind try to hang 100lbs on it.
