For those in the Southern to Central California, and western Arizona, there will be a Falcon 9 launch from Vandenberg SFB today at 2039 PST (8:39 PM PST). Flight path should be southeasterly direction. If the sky's are clear in your area, you should be able to see the launch. Look toward the Channel Islands. Main Engine Cutoff (MECO), Second Stage Speration, and fairing deployment should be visible and all happen around T+2:00 in the flight. Decent of the First Stage should also be visible for awhile.
Also, on the 29th of Nov, there will be another launch. This one is Firefly Alpha. It will launch around 1600 PST (4 PM PST). The flight path may be toward the southwest so Arizona may not see it.
