Wench maintenance
pk104
Jun 30, 2009
208
Catalina 310 Atwood Lake
Just cleaned, oiled and greased my jib wenches. Now I need to do the two on the cabin top. I procrastinated a few years more then I should have and they were very dry inside. Luckily all the parts were still in very good condition. Might mean I'm not sailing enough?
When is last time you did your's?
Apr 8, 2010
2,259
Way to go!
A gross pun in EVERY sentence......
Best thread today!!!
:wow:
LB
Feb 6, 1998
11,772
Dirty wenches are the worst, a well lubed wench is much better. However, you really need to use the correct wench lube not just any old lube will do, it must be wench rated.....:D;);););)
Oct 10, 2010
269
Hunter H260 Gull Lake
I would like to upgrade mine to a self tailing wench. That would be fun to watch while sailing.
Well done everyone!
gpd955
Feb 22, 2006
1,164
Catalina 310 Cape May, NJ
If all the wench parts are in good condition it may mean you're sailing too much!
May 6, 2012
303
Hunter 28.5 Jordan, ON
I just did mine the other night! And it doesn't really matter if I neglect it, I just make sure to use a long handle and lean into it for the best results.
pk104
Jun 30, 2009
208
I knew it would be interesting but way more then I expected. Well done!
