Hello, I am a new owner of a 1974 C22 which was gifted to me. This forum has been incredibly helpful to me already in understanding how this boat is constructed and should be maintained or serviced. I am hoping that I can get a little help and guidance on the approach to a fiberglass repair of the keel hinge pocket resulting from a weldment extraction (gone bad...). In grooming the boat which had sat on the trailer for 5 years with the PO, I discovered she was missing the starboard, aft keel bolt. In short, the fastener was broken off in the weldment and in the process of preparinging to remove the fastener with an extractor the other starboard fastener also failed (with almost no torque applied) in place. After failing to remove either bolt with an extractor, I subsequently excavated both starboard weldments. The forward weldment was punched out from below, cleanly. However, the aft weldment was stubborn and after many hours of pounding and additional excavation still wasn't able to be removed. I subsequently worked from above and found that the weldment plate easily pried off and exhibited significant corrosion on the neck of the bushing. So, I was left with the bushing barrel, still buried in the hull fiberglass. This time, I struck the barrel from above which worked, but... a large, conical plug of fiberglass came with it! Below are pictures of the broken weldment and the fiberglass with SS weldment bushing as removed and also pics of the two pieces fitted together.
So now I am left with a hinge pocket to repair and could really use some thoughts on the best way to repair. below are pictures of the hinge pocket now:
I suppose that I have two options:
1. Build a mold around the outboard hinge pocket area and poor thickened epoxy into the hole (thickened with chopped fiber?). Sand, form and drill new hole for weldment, or
2. Apply highly thickened epoxy from below in successive layers to build up. Then seal from above with poured epoxy. Sand, form and drill new hole for weldment.
Comments or Recommendations?
I will take any advice or commentary you have!
