welding stainless steel
628
Legnos, Starwind, Regal Mystic 30 cutter, 22 trailer sailor, bow rider NEW PORT RICHEY, FL
ok, i know this is dumb. Can you weld ss with a stick (arc) welder? I have an old Lincoln 220V arc welder. I have heard-somewhere- that you can get special welding rod for aluminium, but what about for ss. I just need to run about a 1 inch bead on 1/8" bracket )its the base of my Schaefer roller furler on the Oday25. Now that the dinghy is done i need to finish up the Oday, then the "free boat". I just got the Coast guard paperwork yesterday, woohoo. Patrick
howard
Oct 6, 2008
17
Pearson 422 brunswick
yes you can. local welding shop and ask for them. practice on something else, it is a little different. turn the amperage down some.
Oct 2, 2006
1,517
Jboat J24 commack
NO NO NO
Stick on SS just makes a BIG UGLY MESS
You want it done with TIG and you want the filler wire stamped with 316 on the ends
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
If you don't use the right welding wire... you're going to cause a serious corrosion problem. :) You're generally much better off welding stainless with a TIG or MIG welding setup...not just a plain arc welding setup.
Ross
Jun 15, 2004
14,693
NO NO NO
Then you simply don't know how to weld with stick. TIG is wonderful but stick will do the job if you use the correct size rod and the correct amperage. I have used several pounds of ss coated rods.
Oct 10, 2006
492
Oday 222 Mt. Pleasant, SC
I would think at the least would be to use a MIG welder. 308 and 316 spools are available. Stick welds typically end up looking like birdpoop.
Ross
Jun 15, 2004
14,693
If your welds are not pretty then you have one or more problems. Your amperage is too high or too low, you may be using an AC welder when you need DC, your polarity may be wrong with your particular rods, your rods may be too large for your work, you may lack experience or skill to do a neat job, your welding shield may be too dark or too light for good visibility, you may have failed to clean the weld area properly. You can do just as good a job of screwing up a welding job with oxy-acetylene, MIG, TIG, or coated electrode or you can do a decent job on most projects with any of the methods. TIG comes into its own on thin sections because you can control the weld puddle more precisely. MIG lays the metal down as soon as you strike the arc and you have to keep moving. Stick does the same thing as MIG but interrupts you when you run out of stick.
Sep 25, 2008
992
Oday 25 Gibraltar
SS stick welding works better for larger weld fillets. A GOOD welder can do a nice bead on smaller stuff, but a TIG or a MIG is better suited for what you want.
Oct 10, 2006
492
How do you keep slag from forming with your stick welder? How about contamination in the weld from happening? Without the inert gas, there will be both, unless I'm mistaken.
Ross
Jun 15, 2004
14,693
The coating on the stick burns to form a gas that shiels the arc and also melts to cover the weld pool or puddle. If you can see well the molten metal has a different color than the molten slag. If you have a good arc the puddle will be well formed and shiney. If you arc isn't burning in contact with both pieces the melt puddle will be unstable and will swirl a lot. That means that the angle of the stick is not equal for both sides of the weld. The smallest ss electrodes I have used were either 1/16 or 3/64 and only about eight inches long. The other thing that can interferr with a good weld is wet electrodes.
caguy
Sep 22, 2006
4,004
Ross have you seen or used the welding hoods that have a light sensitive glass. Its clear until you stike an arc. I saw one at Harbor Freight seemed to good to be true.
caguy
Sep 22, 2006
4,004
The reaction time is what I was worried about. Do you see the flash? My eyes are one of the few parts that still work on this old bod, and I'd like to keep it that way.
Oct 2, 2006
1,517
Jboat J24 commack
I have a auto hood that is adjustable from shade 10 to 13+ as i TIG a lot of thin SS as well as heavy bars up to 400 AMPS and its INSTANT and there are far less eye problems that the old style hoods
Apparently nobody in the marine industry knows how to stick weld because i don't see any stick welding on sailboats fittings
Even MIG is going to leave a lot of unnecessary splatter to clean up no matter how much spatter guard you goober all over it
And yes i run a fab/repair shop with stick/mig and tig and if if you even use a polishing tool on steel and then SS it will be rusting until you do it OVER
Ross
Jun 15, 2004
14,693
The auto hood is the same technology as is used for military pilots for protection from nuclear weapons flash. It is micro seconds.
Dec 4, 2006
279
Hunter 34 Havre de Grace
I have one of the Harbor Freight hoods. Yes it's fast enough.
For me and my little MIG (also from HF) though it's too dark, even on the light setting.
I can't see what I'm doing.
Of all things, the cheap hand held shield that came with the welder works best for me.
5,802
Patrick, see what you started? So what's it going to be, stick or TIG? And are you going to get a new Harbor Freight hood? Since it is an O'Day I would go with the stick.
Don't flame me guys, just kidding. Seriously, if it is under the furler drum who is going to see it? I guess you do have to consider the rust thing though.
Jun 4, 2004
273
Oday 25 Alameda
the guy wants a one inch bead on 1/8 inch material. fat chance of that happening with a newbie + stick.
the posters here are offering good advice that will save some grief for the OP. smart money for one little weld is take the parts to a local welder and have it done as a bench job. pay the money and move on.
this is not the job for a DIY learning experience.
Ross
Jun 15, 2004
14,693
1/8 inch ss is thick stock for welding purposes. As I said if you know what you are doing you can make good welds with stick but if you don't know what you are doing hire someone that does.
