Weld Mount system
12
Hunter 356 Oceanport, NJ
Hi,
Has anyone used the Weld Mount system for securing wires? I am trying to secure a couple of single cables for the Victron battery monitor that I just installed, and it seemed like the AT-3 wire tie mounts would allow me to avoid drilled any holes to secure the single cable. I looked at self-adhesive mounts but the reviews weren't very good.
Thanks!
KD3PC
Sep 25, 2008
1,069
boatless rainbow Callao, VA
I have used old ATT/T&B mounts with either a drop or two of 5200 (permanent) or the adhesive of your choice...I do take any adhesive provided with the mounts off and apply mine directly to the mount. I use the blue painter tape to hold it until it sets.
I have some 18"x18"x2" concrete pads mounted to a large 4x8 sheet of plywood with 5200 that my kid used for lacrosse practice, still in great shape since 2004....
all the best
Feb 6, 1998
11,722
Hi,
Thanks!
Pretty much all I use! The stuff is bomb proof but quite expensive. Keep your open adhesives refrigerated and DO NOT cross contaminate the two sides. Mark the cap and the tube with a Sharpie marker so it always goes back on exactly the same way it came off. Cross contamination can kick a tube pretty quickly and at $28.00 - $34.00 per tube.....
Once you build up a kit the cost then becomes the adhesive & nozzles which is not too offensive. The adhesive goes a long way if not using the Weld-Mount Studs..
The Weld-Mount studs are one of the best things I've come across in a long time. Our water heater is held to the boat with them!!! Tough stuff....
Aug 2, 2011
12
Thank you very much for the quick reply. I am new to marine wiring and I have decided that I want to imitate you guys on this forum; do it right the first time, with the right parts.
Aug 2, 2011
12
I had another electrical issue but I am too shy to ask....I want to figure out how to wire my new hour meter to my ignition switch: what gage wire would be safest? Spade connectors or solder the connection? It's a Seachoice Square Hour Meter-Black Bezel SCP-15321, being panel mounted next to the tachometer on a Hunter 356.
