Weeping keel
Jan 28, 2017
26
O'Day 34 Suttons Bay
I’ve been watching a bulge on the starboard keel since purchase in 2016. Rust stains and signs of surface delamination led me to have it explored before repainting the bottom. After grinding off the patch it peed water for 10 minutes. Further investigation revealed a saturated foam compartment above the transverse crack. Still investigating but am curious if anyone knows how many keel voids the 34/35s have and any insight into how this started taking on water.
dmax
Jul 29, 2018
1,193
Telstar 28 Buzzards Bay
I have a 35 with a lead fin keel, can't tell if yours is lead or cast iron. Mine has 3 pockets filled with foam as shown here:
at the top as
JamesG161
Feb 14, 2014
7,766
Hunter 430 Waveland, MS
It is Lead, see his pictures of hammer marks.
Jim...
dmax
Jul 29, 2018
1,193
Thought it was lead but most of the 34's were cast iron so didn't want to assume. The stains might not be rust, could be from the foam.
Likes: JamesG161
Jan 28, 2017
26
I have a 35 with a lead fin keel, can't tell if yours is lead or cast iron. Mine has 3 pockets filled with foam as shown here:View attachment 216047at the top as
That’s very helpful, thanks! The horizontal crack is at the floor of the chamber so I suspect water got in and froze (it’s a Great Lakes boat) causing the lead to split.
From your photo, I’m guessing the water got into the foam from a keel hull joint sealant failure. I’ll pass that along to my repair guy.
Likes: JamesG161
Why in the world would a builder put those foam pockets in a keel? :yikes: To save money on lead or iron? I'm having trouble understanding what the possible reason would be. Is/was this a common practice? I don't recall ever seeing that before.
dmax
Jul 29, 2018
1,193
No idea, I had the foam removed. Never saw it before either. Maybe they wanted to reduce the ballast weight a bit without changing the shape/size, fine tuning.
Benjamin: sounds right.
Aug 17, 2010
327
Oday 35 Barrington
The original design of the 34 used a cast iron (7.874g/cc) keel. When O'day switched to lead (11.34g/cc) they needed to reduce the amount of metal used in order to achieve the same ballast ratio.
One great aspect of the upgrade from iron to lead for the keel is that because there is more weight in the lower part of the keel, the center of gravity is lower, thereby making the lead keel boats more stable.
This is the best picture that I have of the foam in the keel, taken when I had my keel bolts replaced.
  • Helpful
Likes: JamesG161
