Good morning all,
Cat 30 TR 1986.
We are all familiar with the leaking mast/compression post on this boat. At this point I do not believe I have a rotten block or compression post issue - the deck around the post shows no signs of sinking or cracks in the gelcoat.
However I get significant water leaking out of the bottom of the compression post onto the sole of the boat as well as down through the post which drains into the bilge via the electrical wires.
When I called Catalina, they suggested I use a dremel and drill "weep" holes into the deck step, as in 1/2" little "half moons" one on each side.
Looking at my deck step I am not sure this is feasible, and I am not truly sure it will solve the problem either, and so I am hesitant to drill these holes into the step.
Has anyone ever been recommended this solution or tried it? If so, pictures of it would be much appreciated!
Thanks!
Cat 30 TR 1986.
Thanks!
