weather helm
Tom
My boat (hunter 25) has a terrible weather helm. It didn't last year. I believe that the rigging affects this. Anyone know.. do I try to pull the mast forward or aft? Thanks
C
Chris Phillips
hmmm....sounds familiar
Tom, I also have a H25 and it has a pretty bad weather helm. I'm going to try and rake the mast forward a bit and see what happens. What size headsail are you using? I primarily use a 150 genoa in thur night racing and if the winds are up a bit boy do I have a fight on my hands. Good luck. Hopefully you'll get a few more responses than I did when posing this question! Chris
Jim
ease the backstay
In all likelyhood you have raked the mast too much. I've been sailing an an h25 for several years now and I've found that I need very little backstay tension generally. Hope this helps. Jim s/v Cygnus
Brad Stone
Forward...
Rearward rake will increase weather helm, and forward rake will decrease it. I've been playing with forestay/backstay adjustment on my 25.5. I felt I had no feel in my tiller, so I loosened the forestay 2 turns, and tightened the backstay 2, giving the mast more rearward rake. Went sailing, and the difference was quite an increase in weather helm. I'm going to reverse that by one turn to ease it a bit. In your case try the reverse to reduce rearward rake, perhaps 2 turns, easing the backstay and tightening the forestay, go sail and see where your at. Adjust from there. I use a Loos gauge to check final tension. Good luck, Brad
