Weather Helm....
NYSail
Jan 6, 2006
3,187
Beneteau 423 Mt. Sinai, NY
Hello all you P36-2 owners. I have a 1986 Shoal draft with centerboard. I have quite a bit of weather helm when the wind pipes up above 15 knots. What do others do to rectify.....
I drop my board and sheet out the main, but still not as balanced as I would like at higher wind speed.
Mast is centered in its base on the sole and baby stay has a nice bend in teh mast.
Thanks
Jul 15, 2011
25
Pearson 36-2 Mathews Point
When you say you drop the board, is it all the way down. You might try raising it some which will effectively move it backward and should help the weather helm. I admit I am getting lazy in my old age and have not really pushed my 36-2 upwind that much and as shallow as it is around here I tend to leave the board up so I don't have to raise it to get back in the home channel. Also my wife gets upset when we stop suddenly.
Apr 19, 1999
1,670
Pearson Wanderer Titusville, Florida
In simplest terms, the primary cause of weather helm is the center of effort (CE) of the sail plan being farther aft than it should be. Other factors, such as heel, also lead to weather helm, but moving the CE forward will address the secondary causes as well. Here are two simple fixes for the range of wind speeds you mentioned.
The first is to reef the mainsail. Wind force aft of the mast, is trying to turn your boat up into the wind like a weathervane. Reducing mainsail area will reduce that force. The CE of a reefed mainsail is forward of (and lower than) the CE of a full mainsail, so reefing the mainsail moves the CE of your overall sailplan forward. Lowering the CE reduces heel which improves the symmetry of the hull shape underwater. Racing crews and dinghy sailors typically don't reef as readily as cruising sailors do because they can hike out to help keep the boat flat. Less heel also means less drag, which makes the boat faster.
The second thing you can do is reduce the headsail area to the size of a working jib (100% or 110% jib). It may sound odd because you would think that increasing the headsail size would move its CE forward. However, a large headsail like the popular 150% genoa has a THIRD of its area aft of the mast, where it doesn't help. A 110% jib has its area and its CE forward of the mast to do the most good when the wind picks up.
Frankly speaking, reducing sail when the wind builds is inconvenient. Even with a roller-reefing headsail, both genoa cars have to be repositioned to maintain the proper sheeting angle. However, turning upwind in a 15 kt breeze can double the speed of the apparent wind and quadruple its influence on the sails, rig, boat and crew. Setting up the rig to make reefing simple and trouble-free will pay huge dividends.
By the way, weather helm can be reduced by using sail trim, but its not as universally applicable as reefing nor as worry-free. It also requires investing in more boat part$....
NYSail
Jan 6, 2006
3,187
Greatly appreciate the wisdom... out this past weekend with gusts over 16. Did my typical reef down to about a 140 and she sails beautifully..... Reef and reef often.
Thanks all
