Traveller comments
We tend to experiment a great deal with Teliki. In 10 - 15 kt winds an upwind traveller setting will introduce more "twist" and deeper draft in the main than you want or need. You will also heel more than you want or need. You now have less rudder in the water and more lift from the main - since it is behind the center of lateral resistance the boat rotates to windward aroun d the CLR. You don't have enough rudder in the water to hold her off.There are many other forces at play here i.e. it's not this simple, please don't rip me apart - but it sounds like you need to depower your main (flatter sail) and reduce heel (less main sail).We found this works (for us) in higher winds:- adjust headsail for the point of sail (sheeting angle AND sheet tension)- tighten main halyard and outhaul as much as possible- adjust traveller position and main sheet to give the smallest "slot" between head and main where the main is not backwinded. Close hauled, this tends to have the traveller only slightly to windward and the main sheet hauled in as tight as we can get it.- if we are heeling beyond 20 degrees, the main gets reefed accordinglyTeliki goes like a skinnned cat when we do this - and we can take our hand off the tiller for a good 30 seconds at a time. With the stock rudder, the main sheet needed to be VERY tight i.e. flattest sail possible. With the Ida rudder, it doesn't have to be so tight.I might mention that the stock rudder has material "relieved" near the head so it can pivot forward about 1.5 inches (at the bottom) further than stock. This seems to provide a little more "aerodynamic balance" effect but it still takes more deflection than the Ida, due to a lower lift airfoil section.Chris
