weak deck
Doug
I have a 1974 Chris Craft motor sailer the deck on port and starboard side are weak and soft there were deck leaks that I have fixed but now the decks is there and easy way to repair the decks? the marina wants $9,000.00 to fix the two area's both about 4' long by 16" wide I would appreciate any knowledge shared or any refrence books available thanks
Paul F
Jun 3, 2004
827
Hunter 1980 - 33 Bradenton
drill and fill
It is fairly easy to use epoxy that seeps into the deck and seals it, hardening the deck. These products can be obtained from any marine store. I did a similar spot on my deck a few years ago and it is as hard the original deck. My cost was less than $100.
Jerry
Soft deck fix.
I have seen our guys complete this fix about 6 times over the last 2 years. Hopefully, you are not talking about an area around a deck fill, chainplate, or some other penetration. They set a circular saw shallow to just cut through the top layer of glass, down to the core. The cut piece is carefully removed and the backside cleaned and sanded. The soft core is removed down to the inner layer of glass. Closed cell foam sheets, to replace the core material, are cut and epoxied in place. The removed top layer is glassed back in place and faired. Once the new paint or nonskid is done you should not even see the repair.
