You shouldn't need a check valve. I apologize if I'm teaching you to suck eggs, but here goes. Open the Y-valve under the sink (forward bulkhead). Full right (looking from aft to forward) opens the valve to drain the refrigerator. Full left (counterclockwise) opens the valve to the shower sump. Open the raw sea water intake seacock for the head. This is where the shower sump drains. Turn on the pump (switch on the electrical panel and then the switch in the head). The pump should pump the water up above the waterline of the boat, through the Y-valve and discharge through the raw water intake. Since the loop goes above the water line, and since it can get air from the head valves on the discharge side, it should not siphon or put water back into the shower. Check/clean the filter, on the same bulkhead as the Y-valve.One question so far. When running the shower sump it pumps all the water out but then when you stop the pump some water comes back in. Is this normal? Almost like it needs a check valve somewhere?
Thanks, Mike
Note: This plumbing, in the later models of the C-310, is different than the earlier models. The documentation that came with my boat shows the earlier installation.
I made the attached diagram of where things are in my boat. It is entirely possible your boat is different.
