Watertank Mounting
8
- - Orlando, FL
My Son and I are doing work on our 1989 Hunter 23. The water tank has a hose that feeds into an electric pump (Pump works fine) and then to the faucet. Should the watertank be mounted inverted so that there is gravity help in feeding the water or should it be upright with a plastic tube that goes down to the bottom of the tank. Any assistance would be greatly appreciated.
C
Chris
If the pump will lift the water
over the top of the tank and feed the faucet with no problem, then leave it vertical as original. Laying it down is asking for leaks. Why did you complicate matters and increase water usage with an electric pump? The manual faucet/pump works fine...
