water
Hi there! Could you be a little more specific as to where the water is and under what circumstances it appears (sailing only, all times, after rain)? If you are refering to the compartment where the bilge pump is then it could be comming from water being pushed back into it. On a port tack when heeling, water is pushed through the opening and back into the pump and into the bilge. This problem is solved by using one way valves or looping the tubing above the through-hull fitting. alanp.s. check ALL compartments, under sinks, under seats and the top of the ballast tank if possible.
