28.5 bilge
Andy, I think you are referring to the bilge area directly forward of the engine bilge.  This area is not accessible on the 28.5 unless you take up the whole cabin sole.I drilled a hole from the next, forward bilge (the one with the 4 screws) through the stringer into the "hidden" space.  I use a kitchen "baster" with a peice of 1/4" tube attached to drain the area.  You have to be careful as there are wire/water pipes running through this space.There have been many suggestions on this site as to where the water comes from?????Hope this helps.Dave McIlveen28.5 "Osprey"
