I have a H376 with the same problem. The thermostat is inside the immersion heater and is non-adjustable.
There may be a reason for this. We were gunning the engine for quite a long time one day and it was running hot.
Next day when we plugged into shore power - no hot water.
Reason, the engine temp had heated the Seaward tank to beyond the point where the automatic overheat cutout tripped. i.e. it thought the electric thermostat had stuck in the ON position.
Took some time to diagnose but the cure was quick. Just remove the cover over the immersion heater and press the red(? I think) button.
Power was restored to the heater.
Also by having maximum amount of hot water, which gets diluted when water is drawn off, means more useable hot water.
If the water temp represents a problem one can fit a mixing valve on the hot outlet pipe to blend some cold with it whenever a faucet is turned on.
