Gasp
“The Gasp ReflexLoss of breathing control begins the moment water makes contact with the skin, triggering a series of huge involuntary gasps for air. If your head is underwater when you gasp, you will immediately drown. Example: Oct. 1987, Water temperature: 41°F. Fit paddler, calm waters, folding double kayak with 36" beam. Found hanging upside down in his boat, having made no attempt to exit. Not dressed for immersion.” This is a quote from Atlantic Kayak Tours which has articles on cold water safety.If the water is real cold and your not dressed for going in, survival time is apparently quite short. In the spring the air is hot and water cold so it’s hard to wear protection for immersion, float jacket ,etc.The CG has info on this, with survival tips ,like being able to get back aboard quickly, wear a hat, huddle to retain heat, don't thrash about.From a chart we have it shows : 32-41 maybe 1 hr /41-50 maybe 2 hrs /50-59 maybe 3 hrs.There is a local(I think) saying ,The 50/50 rule: 50 degrees,50 yards to shore,50 percent chance of making it!Being clipped on and using safety netting ,so it’s difficult to get overboard ,seems like a good way to enjoy the part of the season were you wouldn’t want anyone in the water.
