OK I did a search in the archives but either I did not do it right or I missed it and therefore have to ask for some help. Sunday when I shut the engine off (3GM30F), the buzzer didn't sound off as it normally does when there is no more pressure. I had run it at 3000 RPM for the last 20 minutes of the run. So today I go to the boat to investigate. Checked coolant level and everything is fine so there has been no overheating. Oil level is right where it should be and oil looks good. So I'm thinking it's an electrical issue.
Checked and cleaned connections on temp and pressure senders but they seemed OK even before I cleaned them. Checked connections behind panel and good there also. Wiggled and then undid & redid the 2 connectors behind panel and the 2 near tranny several time so see if I could get the buzzer to sound. I had left the key turned on and I could hear the hour gauge clicking so I know there is power at the ignition switch.
Checked the alarm itself with the switch on the panel and it does sound off when switch is triggered. Checked the wiring for damage and did not see any. Engine starts and runs fine so I do eliminate temp and pressure problems. At this point, I know the engine would have to overheat for the water temp alarm to sound off so I believe the problem is probably caused by the oil pressure sender. Can it be checked without taking it out and how ? Thanks for the suggestions !
