I see your in Seattle, you may be lucky, the welding process you need to do on your tanks is the very same process used to patch roto molded kayaks. Roto molded Kayaks are inexpensive sea kayaks and also the kayaks used to run rapids. Call a few shops. I bet you will find one that will travel a bit. You can put the welder in your back pocket.
