Hey folks, what is the original water tank made out of? Im wondering if I should just replace all the hosing, and clean it somehow (reuse) if its aluminium? If its stainless, anything I should be worried about? If I can re-use it, im assuming just a shock of some sort (chlorine maybe?) should do the trick? Anything I should be worried about?
My other idea was to cut it out, and use it as the chain locker (altho I think the fill hole is too close to be used effectivly).
Thanks!
Nowell
#176 - 'Aquila'
Thanks!
Nowell
#176 - 'Aquila'
