David Popken
My original 1978 aluminum water tank has been corroded at one end by a long neglected (not by me) chain plate leak. Now that the leak is repaired, I need to address the corrosion on the end of the tank. One of the local repair guys suggested grinding off as much corrosion as possible and then applying zinc chromate to the clean surface. He said it was very caustic and not easy to handle. I am unfamiliar with this chemical. My thought was to grind and then encapsulate in fiberglass. Any comments or other ideas?
