RichH,
I do not understand your post.What are you saying is BS specifically?As to your statement:" So ..... what does one do with municipal water that has a dosage loading of 0.5 to 1ppm chlorine in it already as a 'typical' specified background? Most surface supplied municipal water in the USA is so treated. "I do not understand what you are saying. Depending on the testing and treatment methods, 1 PPM of "chlorine" is not going to destroy your aluminum tank. Municipal water is not alkaline enough to do that.As to:" ASTM methods are a 'testing' standard not a bio standard. "ASTM does have some biological test methods as I recall. Coliform? Isn't that an ASTM standard test?As to:" So .... why hasnt the NSF standards met whats going on in federal specs./guidelines for all municpal (surface) water systems: such a filtation to 1 micrometer absolute to affect a ~100% titre reduction of ALL chlorine resistant organisms. Is it that the RV folks doent know how to read? "I simply do not understand what you are asking / saying.
