I bought this tank monitor system for the fresh and waste tanks on our C310. http://levelguardproducts.com/marine-rv/marine-multi-tank-monitor.php I like that you don't have to calibrate it, since it uses 4 sensors per tank. Hopefully it will work well.
Wondering about the best way to get the wires from the water tank to the electric panel. Following the hose to the bilge is pretty tight, and chafe prone. I couldn't see any other way, however. Once in the bilge it doesn't seem to bad to follow the bilge pump wiring.
If you've done this I'd love to hear what you did.
