Water Tank Location on Oday 22
22
Hunter 33 New Orleans, LA
I have a 1980 Oday 22. I have a 3 gallon water tank on the starboard side in the cockpit storage locker, towards the front. I wonder if this is the original location for the water tank on these boats? It seems like this is not the best place for the tank since the hose has to be several feet long before it gets to the faucet. Also this is probably the reason I have to prime the faucet every time I want to use it. The hose crosses from starboard to port under the cockpit. I am curious where other Oday 22 owners might have their water tank stored at and how big it is? I am thinking about relocating mine to the port storage berth if it will fit there, I never took measurements yet. Chances are that area is too small.
Dec 9, 2006
694
Oday 22 Hickory, NC
One guy had put a bladder and pump under the v-berth, seemed to work well. I am plannling to do that too.
I have seen photos, and mine is plumbed to where the hose goes from the faucet to under the platform the port-a-pottie sits on to that cut out area at the center of the v-berth. it was a 5 gallon blatter type.
Jack
Jul 5, 2010
161
Oday 22, Mariner, Challenger 15 Michigan
My boat is a 1980 model and has the same tank location as yours. I don't have any problems with the faucet working.
Apr 25, 2010
104
Oday 22 Wellfleet MA
My 1983 O'Day 22 has the water tank in same place. I don't use it. Daysailer
Jun 2, 2004
1,956
Oday Day Sailer Wareham, MA
If you need to prime the pump every time you use it, you are either going a long time between uses or have an air leak in your pump. Most hand pumps used on boats for the galley or head sink have some form of built-in check valve so they remain primed between uses. You might also have a leak somewhere in the long hose, again....causing the pump to lose it's prime.
Jan 14, 2010
18
ODAY 22 LAKE ONTARIO, NY
I have a 1973 O'Day 22 and I have a 5 gallon bladder type pump in a space under the v berth.
