R Shelby
I thought my bilge pump was working a little overtime lately...Thougt I might have still have a deck leak somewhere, but no. It's the aluminum water tanks, both of them. After 22 years the old corrosion monster has eaten a little hole somewhere. Pulled the gauge out and peeked inside: corrosion city..an aluminum oxide factory. Plan "A" is installing a bladder, after cutting an access hole above and forr the inlet/outlet lines. Replacing the tank with poly is out of the question. The setee is apparently an important structural component of the hull, and the whole top would have to come off. Plastimo and Vetus flexible tanks which would fit are about 40 gal, so we'll lose some volume, as well as pick up some "off flavor". These are the standard "Florida Tank" 54 gallon jobs that are original on this series of hunter. Those of you out there with 20 year old aluminum tanks: be warned, your time is coming. Makes me worry even more about those few drops of water eating away at the diesel tank (yikes!).I know this topic has been explored, but any advice is welcome. Is a there a baffle in this tank?
