Water Tank issues
Nov 13, 2010
11
Hunter Passage 42 New Orleans
We sail a 1992 Hunter Passage 42 and are in St Martin right now. The last two times we were empty and filled the tanks our side tank would start to overflow after about 20 gallons.
Wahoo can carry about 150 gals of water in two tanks. We usually get 10 days to 2 weeks when it's just the 2 of us aboard. But about 2 weeks ago we went down to about a week before running out of water. However, as I mentioned above, we could only add about 20 gals to the side tank before it acted full (the vent and the fill started overflowing). This tank normally takes about 85 gals.
We've checked the filter and blown out the lines - all seem clean.
Anyone have a clue as to what's happening?
Rick D
Jun 14, 2008
7,208
If it were your fuel tank, I would wonder if the pick up was fractured somewhere. However, your water tanks outflow is on the bottom of the tank, right? Assuming the tank is aluminum, is there an inspection port accessible for you to try to figure out what's going on? I don't have any other suggestions; perhaps some of the smart guys here may have ideas. Good luck!
May 24, 2012
64
Hunter 42 Florida
We also have a P42. I looked at the download section (GREAT resource for us owners) and it seems to confirm what I remembered. The tank does NOT have a bottom outlet but has a pickup tube in it. Sounds like the tube may have broken off and only be allowing you to use the top portion of the tank.
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
Good call FF! Maybe he will get lucky and be able to push more pickup hose down into the tank. Chief
