water tank , batteries, feul tank
8
Hunter 25.5 Dartmouth MA
I was wondering if anyone could tell me where the above items are installed and what size of ea. are required? I do not have a digital camera to take a photo of the area I think they go in. I looked under the galley sink and see what I think is a feed line for the water but I can not see where it goes to in the stern. My wife and I are first time boat owners and are trying to learn everything from scratch so thanks in advance for your patience. John and Diane Gardiner
NULL NULL Indiana
On my 25.5
the water tank is located in the starboard lazerette. I have an inspection plate on the "floor" of the lazerette that can be opened to clean the tank. A water lines runs from the tank, is split into 2 lines with a "T" fitting, passes through an area below the stern bunk, through two electric pumps and then to the two sinks. Remove the cushions in the stearn sleeping area and move the wood covers to the side. I have two batteries located below the rear dinette seat. I am not certain of the volumes, but I think the fuel tank holds around 10 gallons. Probably about the same for the water tank, but, again, I have not measured and have no specs handy. I don't use the water tank because the water tends to get quite stale over a summer and grows nasty life forms if not used and treated often. I have an inboard diesel engine and the fuel tank is under the forward dinette seat. I have a fuel guage on the tank and a valve to shut off fuel flow on the top of the tank. My 25.5 may or may not be typical. A number of modifications were made by the last owner.
Scott
Locations
My water tank is under the starboard lazerette and it holds 12 gallons of water. My batt is under the aft dinette seat. I do not have a fuel tank onboard since mine has an outboard. My 25.5 is located in Mattapoisett at Brownell's if you'd like to take a look
Jan 13, 2005
8
which Brownell's ?
I went by Brownell's on Park St. and at Industrial park to see if I could find you. What is the name of your boat and what yard is it at?
